[LINK]: ETAP 6 and ETAP 7
Тools, Elcad, Eplan, ...
Link
Forum Community
Forum Community
Contact:
Post by Link »
mk2005
Re: [LINK]: ETAP 6
Post by mk2005 »
Good post, but Instalacion ETAP 6.txt isn't on English. Can you translate. Thanks in advance.
Link
Forum Community
Forum Community
Contact:
Re: [LINK]: ETAP 6
Post by Link »
This quoted text is from my etap6.txt
*The cure doesn't work with Windows Vista x64 or Seven x64. The cure is LPT dongle emulator and the driver for this emulator is only for 32 bit OS.
*You MUST turn off the User Account Control (UAC) and reboot before install the cure.
*If you still have problem, try to disable temporarily your firewall.
1. Install etap6
2. after install dont open the program
3. right click the cure and then run as administrator
4. reboot your pc
5. open etap6
6. input activation code if require
7. enjoy
activation code for etap6
QtCD9L 8cxzSq iU3AA4 RsjpAi /ZVArg WiJEG+
wangrenzhi
Re: [LINK]: ETAP 6
Post by wangrenzhi »
Can't Download, Please Updownload to Rapidshare, think you
utuh_garubuk
Re: [LINK]: ETAP 6
Post by utuh_garubuk »
Hi.. ..Can you post crack (cure) only. Please..
Link
Forum Community
Forum Community
Contact:
Re: [LINK]: ETAP 6
Post by Link »
et voilá
http://www.megaupload.com/?d=2JQLU4YB
translate with babelfish
1. - We mounted the ISO with Poweriso or alcohol 120, or its favorite program.
2. - We executed the Etapinstaller.exe with administrator privileges.
3. - Soon Clickean where it says " 6.0.0 ETAP with ETAP License Manager"
4. - Everything Must leave instale. In the end it will install to driver of key USB… this process can take a little.
So patience.
5. - Once it has been finished installing must initiate the program.
6. - It will leave a window to Them that says " Licence Path Selection"
7. - He appears the user and soon they give " ok" and it will appear a message saying that the License was not in the
registry or something thus. Then they go to the route c:\Program Files\Operation Inc. Technology \ ETAP Licence Manager
and open the file ETAPKEY.exe (with permissions of administrator-for view or seven-)
and gives the eyelash him " Install ETAP KEY" and it leaves the message that already this introduced in the registry.
8. - Once installed everything, to decompress the archives of crack, serial and a file etap6.exe
9. - To This file they copy the directory C:\Etap 600. once open it there (with administrator privileges it stops
view and seven) which abrió the system console and announced the search of driver of key USB… in the
C:\windows\system32\drivers directory, which did not find.
But It appears the message to reinitiate the equipment. (this process in some S.O usually it appears in xp I do not
happen to me).
10. - We reinitiated and I executed the direct access of the writing-desk, (with administrator privileges it stops
view and seven) and voila… appeared to me a new window where the serial one can be introduced that comes with crack
and Ready….working.
utuh_garubuk
Re: [LINK]: ETAP 6
Thanks Most... it's working...
ali1358
Re: [LINK]: ETAP 6
Post by ali1358 »
thanks for the links plz re upload part 4
thanks in advance
most
Re: [LINK]: ETAP 6
Post by most »
ali1358 wrote:thanks for the links plz re upload part 4
the part 4 is OK, I tested now
do you have problems with this file :?:
ali1358
Re: [LINK]: ETAP 6
Post by ali1358 »
now it is ok . it;s great thanks.
ALI
oktay59
Re: [LINK]: ETAP 6
Post by oktay59 »
thanks for the links plz re upload part 5
Link
Forum Community
Forum Community
Contact:
Re: [LINK]: ETAP 6
Post by Link »
http://www.mediafire.com/?fiyz2i1mznj
etap 7 is out
the emulator is the same of the etap 6
serial:
9dqDk78cfc#Y8r5NA6SQsrMFJTPMuTBnQ+xy
9dp8kD6Ncc#Y8r5FBL+QEn3DHqDBKR<7Nc4/
mmohamed15
Re: [LINK]: ETAP 6
Post by mmohamed15 »
Dear Most
could u please upload ETAP 7 or tell me from where i can download this version
thank very much
Link
Forum Community
Forum Community
Contact:
Re: [LINK]: ETAP 6
Post by Link »
farshad4017
Re: [LINK]: ETAP 6 and ETAP 7
Post by farshad4017 »
(sos)
Every time I on one component libraries can click this issue before coming.
Who knows why?
My only problem? (wow)
gxlly1023
Post by gxlly1023 »
where is the emulator of the etap 6?
oktay59
Post by oktay59 »
thanks a lot for your links http://www.mediafire.com/?fiyz2i1mznj i downloaded it but i cannot open file plz help me again.
calot2000
Post by calot2000 »
! I:\eTap\ETAP6.0.part5.rar: CRC failed in ETAP 6.0.0.iso. The file is corrupt
d4ni_R
Re: [LINK]: ETAP 6
Post by d4ni_R »
Link wrote: ETAP 7
by luis4170
where's the crack or license? it requests Computer Name or Ip Address of ETAP License Server.
(fback) (fback) (fback)
farshad4017
farshad4017 wrote:(sos)
Who knows why?
please help !
Someone like me it s the problem?
cuongvtc
Post by cuongvtc »
See this instruction
Good luck!
I already tested it with Windows Vista, SP2, 32 Bits and ETAP 7.0.0 is working OK with fully operative capabilities, providing Full Capabilities functions with 65535 busses.
Serial is asked the first time that you open ETAP 7.0.0. If it is not asked, introduce it in the License Manager (go to ETAP Help/about ETAP).
How to Install Etap-7 on Windows-7 32-bit:
1. Downloaded ETAP-7 file is on iso format, so burn it on DVD
2. Disable connection to internet
3. Disable antivirus software on your computer
4. Press F2, go to user account control and disable it.
5. Run Etap-7 installation from DVD.
6. select install + license manager, just follow the instruction. Note : For Win-7 (and maybe Vista, but I never use vista) will show up UAC, just click/select enable to install
7. When finish installation, dont run the software.
8. Open folder LMSETUP\SYSTEM32\DRIVERS on etap DVD
9. copy all files in the LMSETUP\SYSTEM32\DRIVERS ----- to ------ C:\Windows\System32\Drivers\
10. Extract sn.rar then run file " etap7.exe " this is the software to bypass license.
this file is under DOS file, so you will see DOS application run. Note : Why extract to Etap-7 folder, because I've ever fail to run it when extract outside etap 7 folder.
9. After finish install medicine, then Reboot your computer/laptop.
10. Enable again your antivirus
11. Run ETAp 7 application.
11. Will show up window for license , click OK, then software will ask for activation serial
Enter Activation serial : 9dp8kD6Ncc#Y8r5FBL+QEn3DHqDBKR<7Nc4/
12. Then enjoy using ETAP 7
aa110
Post by aa110 »
http://www.megaupload.com/?d=OIJTK3DA
it doesn't work,please upload it ,many thanks!
andy217
Post by andy217 »
I have download ETAP7.0 ,but I can't find the crack, where is the SN.rar? Can anybody help me? Thanks!
andy217
Post by andy217 »
Internet explorer is rubbish, you just can use firefox , it can download the file.
farshad4017
cuongvtc wrote:See this instruction
Good luck!
plz upload crack (sos)
njymgl
Post by njymgl »
I can not download E._T._A._P._v7_.0_.0.part15.rar , please reupload it. Thank you very much!
netomac
Post by netomac »
plz reupload ETAP6 part2.The link http://www.megaupload.com/?d=OIJTK3DA is not available now.
thx
acere63
Post by acere63 »
where is ETAP7.0 crack document?
I have download ETAP 7.0,but ,do not find sn.rar,please get it,if have it.thank you
osmanzain
Post by osmanzain »
plz reupload ETAP6 part1 link http://www.mediafire.com/?zmyktudunit
is dead now :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: plzzzzzzzzzzzzzzzzzzz
tamsky
Post by tamsky »
who can send me the sn.rar by email? I have download the sn.rar file ,but cann't open it ,my email:tamsky@139.com,thank you very much!
Linkinx64
Post by Linkinx64 »
tamsky wrote:who can send me the sn.rar by email? I have download the sn.rar file ,but cann't open it ,my email:tamsky@139.com,thank you very much!
What's a difference between file downloaded from ziddu and file sent to email? If you can't open first - you can't open another.
Disable AV, download again, check WinRAR version...
P.S. the file is NOT corrupted.
tamsky
Post by tamsky »
I think the file is corrupted.I have disable AV,winrar is 4.0.can you send the file to me ?thanks!
Linkinx64
Post by Linkinx64 »
Kaspersky not found viruses but MS OneCare showing this message when I try to add attachment so be careful.
Archive sent.
regards
Linkinx64
tamsky
Post by tamsky »
Thank you for you help,I had installed successfully, but I still have a problem ,that is the serial number is invalid.the message is "An invalid Activaion Code was entered.Please retry!",how can I do ?please teach me ,thank you very much! P.S. my etap version is 7.1,it come from OTI COMPANY,can the serial number still be used?
Linkinx64
Post by Linkinx64 »
tamsky wrote:my etap version is 7.1
Could you upload your ETAP v7.1?
In this case we can check it out and probably fix this problem.
tamsky
Post by tamsky »
how can I upload ETAP V7.1?By MSN?
Linkinx64
Post by Linkinx64 »
Split ETAP to several parts (each part ~ 100-200 Mb) and upload to any free filestore.
Put given links in this topic, or send me via email/PM.
For reference:
regardz, Linkinx64
tamsky
Post by tamsky »
can I send the e*t*a*p 7.1 to you by MSN?
Linkinx64
Post by Linkinx64 »
tamsky wrote:can I send the e*t*a*p 7.1 to you by MSN?
Yes you can. But split to files with size = Min(YourEmailAttachmentLimit Mb, 25Mb) each. Or if you have MSN account - share it on SkyDrive.
P.S. I guess under MSN you didn't means MSN messenger. I'm not using MSN Messenger.
tak2750
Post by tak2750 »
hi
i use etap 7 on windows 7.it work fine.but when i press the calculation in shows this error.
please help me.
tak2750
Post by tak2750 »
who has installed etap 7 successfully on windows 7 32 bit?
alafandy
Post by alafandy »
my PC win7 Sp1 ( 32bit)
single CPU
RAM = 1GB
and
etap 7.0.0 install perfectly, and now working with it.
and install too etap 7.5.0 in my pc , but i have no working key
so im uninstall etap 7.5.0 form my PC.
that mean all etap version working with win7 sp1
Greeting from Germany
tak2750
Post by tak2750 »
thanks
i will format my windows and update it to sp1.
tak2750
Post by tak2750 »
tak2750 wrote:thanks
now it work goode with win 7 32bit sp1
Paris
Post by Paris »
Hello gays, Pls some help on this !!!
Install ETAP 7.0 on Windows 7 X64 SP1
Installation went OK, Licenses manager installed also OK, Licenses manager service started OK.
Copy files from ETAPSETUP\LM32SETUP\LMSETUP\SYSTEM32\DRIVERS to C:\WINDOWS\SYSTEM32\DRIVERS
Execute ETAP7.exe inside C:\Program files (x86)\ ETAP 700 as ADMINISTRATOR
AV was not running, Internet connection was disabled.
ETAP7.exe executed but can not FIND files DS1410D.SYS and DS2490.SYS inside C:\WINDOWS\SYSTEM32\DRIVERS
But files has already been copied to C:\WINDOWS\SYSTEM32\DRIVERS
DOS windows indicate that “TORO SERVICE” not started.
Then Reboot PC and start ETAP 7.0
Program start OK, but on window for entering license when press OK coming the message
ETAP KEY NOT FOUND or LIECENCE MANAGER NOT READY or something like that.
Then delete files previously copied from ETAPSETUP\LM32SETUP\LMSETUP\SYSTEM32\DRIVERS and copy files from ETAPSETUP\LM64SETUP\LMSETUP\SYSTEM32\DRIVERS to C:\WINDOWS\SYSTEM32\DRIVERS
ETAP7.exe executed but again can not FIND files DS1410D.SYS and DS2490.SYS inside C:\WINDOWS\SYSTEM32\DRIVERS
This time the files realy does not exist in C:\WINDOWS\SYSTEM32\DRIVERS
DOS windows indicate that “TORO SERVICE” again not started.
Program start OK, but on window for entering license when press OK coming again the message
Both times either with the files inside ETAPSETUP\LM32SETUP\LMSETUP\SYSTEM32\DRIVERS
(DS1410D.SYS, DS2490.SYS, ETAPSLMT.EXE, OTISVRMSGS.DLL) or the files inside ETAPSETUP\LM64SETUP\LMSETUP\SYSTEM32\DRIVERS (ETAPSLMT.EXE, OTISVRMSGS.DLL) the results are the same
The message ETAP KEY NOT FOUND or LIECENCE MANAGER NOT READY coming when starting the ETAP 7.0
Any help on this ?????
Thanks in advance
Agentz
Post by Agentz »
There's Someone kindly give me file "etapkey.exe" for ETAP 6.
this is my problem:
I succesfully download Etap 6, plus Peta6.
I Succesfully install Etap 6.
following from "Readme.txt", i start peta6 => etap6.exe
but when i start the program, It leave a window that says " Licence Path Selection"
i choose " ok" and it appear a message saying that ETAP KEY NOT FOUND or LICENSE MANAGER NOT READY.
all Step in that "Readme.txt", i do it all.
but not working.
Then, when i read post in this Etap Forum.
i see that......., there is a file called "etapkey.exe". (sbutton)
in my installer directory, there is no this file.
my suggest is!,
my etap doesnt work, because there is no this file.
so, please reupload.
but, just only this file ===> "etapkey.exe"
i think the size of the file is small, not big.
but the file for ETAP 6 only
pliss,
to run this program is just close enough. :? (oo)
but i can't. help me
oleksandr_ua
Post by oleksandr_ua »
all the links do not work (rapidgator.net, uploaded, nitroflare.com) (not_allow) (not_allow) (not_allow)
please give a link where you can download (sos) (sos) (sos)
