Table of Contents for Volume 1
Alarm and Security Circuits
Amplifiers
Analog-to-Digital Converters
Annunciators
Audio Mixers, Crossovers and Distribution Circuits
Audio Signal Amplifiers
Automotive Circuits
Battery Chargers and Zappers
Battery Monitors
Bridge Circuits
Burst Generators
Capacitance Meters
Circuit Protection Circuits
clock Circuits
Comparators
Computer Circuits
Converters
Counters
Crystal Oscillators
Current Meters
Demodulators
Descramblers and Decoders
Detectors
Digital-to-Analog Converters
Dip Meters
Display Circuits
Drive Circuits
Electronic Locks
Emulator Circuits
Fence Chargers
Fiber optics Circuits
Field Strength Meters
Filter Circuits
Flashers and Blinkers
Flow Detectors
Fluid and Moisture Detectors
Frequency Meters
Frequency Multiplier and Divider Circuits
Frequency-to-Voltage Converters
Function Generator Circuits
Games
Gas and Smoke Detectors
Hall Effect Circuits
Humidity Sensors
Infrared Circuits
Instrumentation Amplifiers
Integrator Circuits
Intercom Circuits
Lamp-Control Circuits
Laser Circuits
Light-Controlled Circuits
Logic Amplifiers
LVDT Circuits
Measuring and Test Circuits
Medical Electronics Circuits
Metal Detectors
Metronomes
Miscellaneous Treasures
Modulator Circuits
Motor Control Circuits
Multiplier Circuits
Noise Reduction Circuits
Notch Filters
Operational Amplifier Circuits
Optically-Coupled Circuits
Oscillators
Oscilloscope Circuits
Peak Detector Circuits
Phase Sequence Circuits
Photography-Related Circuits
Power Amplifiers
Power Supply Circuits
Power Supply Circuits (High Voltage)
Power Supply Monitors
Probes
Proximity Sensors
Pulse Generators
Radiation Detectors
Radar Detectors
Ramp Generators
Receivers
Rectifier Circuits
Relay Circuits
Resistance and Continuity Meters
RF Amplifiers
RF Oscillators
Sample-and-Hold Circuits
Sine-Wave Oscillators
Sirens, Warblers and Wailers
Sound (Audio) Operated Circuits
Sound Effect Circuits
Square-Wave Generators
Staircase Generator Circuits
Stereo Balance Circuits
Strobe Circuits
Switch Circuits
Tape Recorder Circuits
Telephone-Related Circuits
Temperature Controls
Temperature Sensors
Temperature-to-Frequency Converters
Theremins
Thermometer Circuits
Tilt Meters
Time-Delay Circuits
Timers
Tone Control Circuits
Touch-Switch Circuits
Amplifiers
Annunciators
Automotive Circuits
Battery Monitors
Bridge Circuits
Burst Generators
Capacitance Meters
clock Circuits
Comparators
Computer Circuits
Converters
Counters
Crystal Oscillators
Current Meters
Demodulators
Detectors
Dip Meters
Display Circuits
Drive Circuits
Electronic Locks
Emulator Circuits
Fence Chargers
Filter Circuits
Flow Detectors
Frequency Meters
Games
Humidity Sensors
Infrared Circuits
Integrator Circuits
Intercom Circuits
Laser Circuits
Logic Amplifiers
LVDT Circuits
Metal Detectors
Metronomes
Modulator Circuits
Multiplier Circuits
Notch Filters
Oscillators
Power Amplifiers
Probes
Proximity Sensors
Pulse Generators
Radiation Detectors
Radar Detectors
Ramp Generators
Receivers
Rectifier Circuits
Relay Circuits
RF Amplifiers
RF Oscillators
Strobe Circuits
Switch Circuits
Temperature Sensors
Theremins
Tilt Meters
Time-Delay Circuits
Timers
Table of Contents for Volume 2:
Alarms
Amateur Radio
Amplifiers
Attenuators
Audio Mixers
Audio Oscillators
Audio Power Amplifiers
Automotive
Battery Chargers
Battery Monitors
Buffers
Capacitance (Touch) Operated Circuits
Carrier Current Circuits
Comparators
Converters
Crossover Networks
Crystal Oscillators
current Measuring Circuits
Current Sources and Sinks
AC/dc and dc/ac Converters
Decoders
Delay Circuits
Detectors
Dip Meters
Displays
Dividers
Drivers
Fiber Optic Circuits
Filters
Frequency Measuring Circuits
Frequency Multipliers
Fuzz Circuits
Games
Gas/Vapor Detectors
Indicators
Infrared Circuits
Light Activated Circuits
Light Controls
Light Measuring Circuits
Liquid Level Detectors
Logic Circuits
Measuring Circuits
Metal Detectors
Metronomes
Miscellaneous Circuits
Mixers and Multiplexers
Modulation Monitors
Modulators
Moisture and Rain Detectors
Motor Controls
Multivibrators
Noise Generators
Phase Sequence and Phase Shift Circuits
Photograph related Circuits
Power Measuring Circuits
Power Supplies (Fixed)
Power Supplies (Variable)
Power Supply Protection Circuits
Probes
Pulse Generators
Radiation Detectors
Ramp Generators
Receivers
Resistance and Continuity Measuring Circuits
RF Amplifiers
RF Oscillators
Remote Control Circuits
Safety and Security Circuits
Sample and Hold Circuits
Schmitt Triggers
Smoke and Flame Detectors
Square Wave Oscillators
Switches
Telephone Related Circuits
Temperature Sensors
Timers
Transmitters
Ultrasonic Circuits
Video Amplifiers
Voltage and Currant Sources and Reference
Circuits
Voltage-Controlled Oscillators
Voltage-to-Frequency Converters
Voltmeters
Waveform and Function Generators
Zero Crossing Detectors
Sources
Amateur Radio
Amplifiers
Attenuators
Audio Mixers
Audio Oscillators
Automotive
Battery Chargers
Battery Monitors
Buffers
Comparators
Converters
Crossover Networks
Crystal Oscillators
Decoders
Delay Circuits
Detectors
Dip Meters
Displays
Dividers
Drivers
Filters
Fuzz Circuits
Games
Gas/Vapor Detectors
Indicators
Infrared Circuits
Light Controls
Logic Circuits
Measuring Circuits
Metal Detectors
Metronomes
Modulation Monitors
Modulators
Motor Controls
Multivibrators
Noise Generators
Probes
Pulse Generators
Radiation Detectors
Ramp Generators
Receivers
RF Amplifiers
RF Oscillators
Schmitt Triggers
Switches
Temperature Sensors
Timers
Transmitters
Ultrasonic Circuits
Video Amplifiers
Circuits
Voltmeters
Sources
Volumes 3, 4, 5 and 6 are similar
http://hotfile.com/dl/25067712/96a95db/Graf_-_Encyclopedia_of_Electronic_Circuits_-_Vol_1.pdf.html
http://hotfile.com/dl/25067714/9444d5a/Graf_-_Encyclopedia_of_Electronic_Circuits_-_Vol_2.pdf.html
http://hotfile.com/dl/25068575/1f79fa6/Graf_-_Encyclopedia_of_Electronic_Circuits_-_Vol_3.pdf.html
http://hotfile.com/dl/25068591/f1353c2/Graf_-_Encyclopedia_of_Electronic_Circuits_-_Vol_4.pdf.html
http://hotfile.com/dl/25069466/a30f2f5/Graf_-_Encyclopedia_of_Electronic_Circuits_-_Vol_5.pdf.html
http://hotfile.com/dl/25069616/175890e/Graf_-_Encyclopedia_of_Electronic_Circuits_-_Vol_6.pdf.html
