[?]: exe files in the folder path (programmfiles/simens/bin)
codemaker555
Post by codemaker555 »
Dear All can any one tell that the exe files in the folder path (programmfiles / simens / bin) what is there exact application any document available ... irequest u to go through the attachment u will certanly come to know what i mean......... :oops:
Important Settings within the WinCC System:
To make it possible to (acoustically) signal messages within the WinCC
system (by means of the audible indicator module) at specific operator
terminals, the signal module run -time module (HMRT.EXE) must be loaded
in the start up list of the client computer
Note:
The SBG RUNTIME module (HMRT.EXE) cannot be connected
within the start up list of the server computer. The
"Alarm
Logging Wizard"
is responsible for connecting the SBG
RUNTIME module in the start up list of each client computer.
The
"Alarm Logging Wizard" is located in the control center
under the
"Editor" "Base" data project components. While you
are editing the Alarm Logging wizard, activate the
"Connect
Audible Indicators"
check box to connect the audible indicators
functionality. You can find this check box in the
"Message
Window Configuration"
window.
