[?]: RSLogix Emulate 5000 v17.00 problems actvation
djcatalyst
Post by djcatalyst »
hi all
I've tried to start training on rslogix and found RSLogix Emulate 5000 v17.00 software
but there are no support of activation or cracked code
there is the link where i found it:
http://duniakendali.wordpress.com/2009/01/26/rockwell-plc-emulator-simulator/
you can downoad there ...
its also nice portal for programmers in any types of PLC
Thanks and i'm waiting for solution from you.
dehell
Re: [?]: RSLogix Emulate 5000 v17.00 problems actvation
Post by dehell »
Hi, follow this link
[dead] :/125422681/AB_pass_33333.rar
Best regards
djcatalyst
thanks alot
i will try it...
djcatalyst
sorry but i cudnt make with this file nothing
after installation it ask me to move the activation from drive to drive .
what i supose to do now?
dehell
Post by dehell »
Hello
First
You have to search on web this software ; Dekart Private Disk. Download this software.
Then install it on your computer.
After installing, run Dekart Private Disk = virtual floppy drive
Open the file AB_pass_33333
Then run Rockwell Software : EMove
Select your virtual floppy drive move the license key on you hard drive.
Best Regards
adam_bodom
Post by adam_bodom »
Hye.
May I request a new copy for Rslogix 5000 v17 emulator and the keys etc?
I downloaded in one link but got error " Error initializing setup file". and an " error during the installation of assembly component".
perhaps can send to adammukhriz82@gmail.com
