Dear All
kindly,i need to know which software i must use for slc500 series plc of allen bradly,any body can provide me link for that along with activation or key etc.
[?]: which software i must use for slc500 series plc ?
Re: [?]: which software i must use for slc500 series plc ?
That do you lake to do?
But of course you mast have the RSLinx Classic (no Lite, Gateway or Single Node activation) & RSLogis500 and cable for your SLC model.
Probably you need the ConrolFlash for firmare update into your processor and smart modules.
If you have more then one rack and the net you also need the RS NetWorx for your net type configuration.
You can use the search function by this forum sucsesfuly.
Good lake!
Good lake!
Thank you for reply, could you get me files for those links? i have installed rslogix 500 pro with period of grace of 7 days,then what i should to do now for unlimited period.Ryzhij wrote:That do you lake to do?
Good lake!
You must to activated your phrograms
http://plc.net.ru/viewtopic.php?f=12&t=6905
Also I found the link for download, please check:
[dead] :/P8WZEO
Folder&files password: WAB
[dead] :/P8WZEO
Can i use Rslogix 500 software which is for period of grace days of seven for communication with the plc ? with the slc 500 plc series and its communication cable connecting.zaji wrote:Dear All
