[?]: Fuzzy program doesn't work.
le_el
Post by le_el »
I have two input "high" and "d_high" and one output in a fuzzy system.
d_high = (high setpoint - high current) / dt
"high setpoint" is set by user.
"high current" is read by sensor.
Is it true if i program in STL language in OB1,OB100 and OB35 ?
Could you please check it for me ?
http://www.mediafire.com/?dcmncidmvzm
Thanks you for this inconvenience.
Best regard.
leegiang
wibile
Re: [?]: Fuzzy program doesn't work.
Post by wibile »
unfortunately,i still can not use the software correctly.Simatic_EKB_Install_2009_08_26 can not work.
fuzzy just likes other FBs,it can be use as u like,but u should use the fuzzycontrol++ to transfer rules to PLC.
if u help me with my software,maybe we can exchange experience..........
SHKODRAN
Post by SHKODRAN »
Normal as he can work so according to you.
Departing from the fact that you have used MD0 Reale and M0.1 and M0.2 boolean merker as you make to check M0.1 and M0.2?
One thing I have not understood...
What do you have to do with this program?
Do you have to command a moduling valve or start stop to a pomp?
le_el
Post by le_el »
Dear Wibile,
if you have problem with this software, i can help you. How to connect between Fuzzy control and PLC. Because i have connected them and i have transfered the rule to PLC.
Best regard.
wibile
Post by wibile »
hi,le_el.I need your help.I have tried both
Siemens_Simatic_FuzzyControl_V5_with_crack.zip and
FuzzyControl___V5.0_2004.rar for many times.The first software seems can
work,but just for cfc.When i click 'selection',and choose 's7-20k',then
click connect,an error appears.And the button "Browse" to chose s732.dll is
grey.
I have installed step 7 v5.4,SIMATIC NET V6.4 and WinCC v6.2.
If it is convenient to you,please email the fuzzy software which u used to
me. My email is vigor@live.cn . Thanks in advance.
le_el
Post by le_el »
i have just sended to you my software that i have used. You should follow in the user's manual to configuration the station with the network and the PG/PC in the control panel in the fist. After that try to connect them.
Hope this help.
Best regard. :)
