[?]: Sticky keys ( Memory bits ) in TP177B WinCCFlexible
Sundar
Post by Sundar »
Hello Guys,
Please help me to solve the below problem.
We are using a TP177 B connected in profibus DP and CP317- 2DP CPU in our project. There are few Plus & Minus buttons in touch panel for setpoint value to drive inverters.
The problem is the tags assigned to these plus , minus buttons are not stable , Example it give continuous signal ( sticky even we removed the finger from the touch panel ) to PLC and leads to unexpected result.
We are using winCCflexible SP1 HF2. Even in WinCCflexible runtime screen also produces this kind of error.
Somebody may face similar problem !
