[LINK]: Key-code and serial WinGP Proface
jhl6
Post by jhl6 »
Has somebody an Key-code and serial for WinGP from Proface?
jhl6
Re: [?]: Key-code and serial WinGP Proface
Post by jhl6 »
Hello again,
I found this link with keycode. http://www.thaiplc.com/webboard/index.php?topic=737.0
Now I can install WinGP.
There is an new problem.
When you use WinGP on an IPC from Proface you also need to enter the keycode in the IPC.
When you use WINGP on an standalone PC (windows xp) you need an dongle.
Has somebody an solution to bypass the dongle?
Thanks.
Jan Hein
