Hello!
I bought the Schneider Electric TSXCUSB485 converter but I don't have the TSXCRJMD25 cable (RJ45 <> mini-din) to connect to the plc. Anyone have this cable? What's the pinout?
Thanks in advance.
[?+]: Schneider Electric TSXCRJMD25 pinout
Re: Schneider Electric TSXCRJMD25 pinout
many thanks most!
Re: [?+]: Schneider Electric TSXCRJMD25 pinout
IS there shortcircuit between 1-8 in RJ45 side
can you made it more obvious
sorry, if i appear stubid
thanks in advance for your help
see the photo (front view, side of the pin)ahmedganainy wrote:![]()
can you made it more obvious![]()
din rj45
1-------------------1
3-------------------3
4-------------------4
5...................5
6...................6
mass ............mass (if exist in your rj45)
do not forget, you need TSXCUSB485 converter
numbering of RJ45 is not like the standard you start from the next side aren't you?
who said that I used the standard numberingahmedganainy wrote: numbering of RJ45 is not like the standard you start from the next side aren't you?
see, for you the numeration of the plug din that i use is standard
see the photo,turns the plug for you with clip for top.
if you have doubt, is preferable to buy the cable TSXCRJMD25 in Schneider Electric
many thanks
i appreciate your help
really i am sorry if i annoied you i was confused .
verifies if it is more explicit
TSXCRJMD25 cable (RJ45 <> mini-din) to connect TSXCUSB485 converter to the plcs :
Permium & Micro & Nano & Naza & Twido
RJ45 Mini DIN8
PMC 3--------------------------------------5 PMC
D(B) 4--------------------------------------1 D(B)
D(A) 5--------------------------------------2 D(A)
NDE 6--------------------------------------4 NDE
GND 8--------------------------------------7 GND
Mass----------------Mass (if exist in your RJ45)
http://entezari.persiangig.com/TSXCRJMD25.jpg
Best regards;
Navid Entezari
Control & Instrumentation Engineer
RJ45 Mini DIN8
Best regards;
Navid Entezari
