[?]: Example control boiler.
примеры программ
Maikon
Post by Maikon »
Looking for an example of control of boilers for PLC.
Can someone help me?
CHANt
Re: Example control boiler.
Post by CHANt »
In our country is not allowed to control the device of the burner caldron from PLC, only include and adjust.
On such device and program needs the state certificate.
If beside You are permitted, that example there is in library on
http://www.oscat.de
В нашей стране не разрешено управлять устройствами горелки котла от PLC, только включить и регулировать.
На такое устройство и программу нужен государственный сертификат.
Если у Вас разрешается, то пример есть в библиотеке на
http://www.oscat.de
jet jiang
Re: [?]: Example control boiler.
Post by jet jiang »
I think it is a complex system to control a boiler , such as the power plant.The better selection is DCS with special calculation methods . But we can use PLC to control the bottom ash and fly ash system and other branch systems. I do the work as an electric and automatic control engineer of bottom ash and fly ash system .
CHANt
Post by CHANt »
Wieshaupt offers a complete solution - burner with S7-300 + software
With the burner comes converter with E-BUS to Profibus, to work with Simatic .
Wieshaupt предлагает комплексное решение - горелка с S7-300+программа
С горелкой поставляется преобразователь E-BUS на Профибус, для совместной работы.
