I am using concept software & Quantum PLC, I have to communicate 40 power meters PM710 which are far away from PLC, so I am using EGX100 to convert ModBus RTU to ModBus TCP/IP, further EGX is connected to NOE77101 & Quantum PLC via Ethernet Ring.
The Quantum PLC has option for Ethernet I/O Scanner, Can I use this for reading power meters? or I have to go for communication block, like Read_Reg.
Regards
LEO
[?]: Can I read EGX via Quantum Ethernet I/O Scanner
leofarhan
genjua
Re: Can I read EGX via Quantum Ethernet I/O Scanner
Yes Farhan you can do that easily.......
use ethernet i/o scanner block at configuration extention.
Regards
GENJUA
Regards
GENJUA
