I HAVE A MP370 WITH THE LCD BURNED (TOTAL WHITE SCREEN).
THE MONITOR IS WORKING OR I THINK THAT IT DOES!!!
IS IT POSSIBLE TO FIND THE IP OF THE SCREEN IN ORDER TO MAKE A BUCKUP?
THANKS
STAMATIS
[?]: TOTAL WHITE SCREEN MP370 and IP ADDRESS
apiranthitiss
Re: [?]: MP370 IP ADDRESS
Use WINDOWS command PING ipaddress, and disconnect / connect a network cable and look when the answer will be lost.
Look for a software called Superscan, this will allow you to make a multiple ping to all the network segment
