[?] Regarding Profibus DP Diagnostic pakage - FB 126
xdoit
Post by xdoit »
Hi to all,
The frequently used FB125 DP_DIA function block and the associated visualization have been replaced by the PNIODiag diagnostic package as per Jan. 01, 2008.
The FB126 "PNIODiag" is available for free downloading from the Internet under the following entry ID: 26996747.
But the following is not a good message.
The used S7 data block s as well as the S7 function blocks doesn't contain any symbolic information. An interface description isn't available. The S7 blocks are only made for usage by the visualisation that are part of the diagnosis package PNIODiag.
I need to make a diagnostic of every node and to generate a "communication alarm" in the Step 7 program for every node. If I use it in automatic mode I can't know which nodes are down in the case of there are more than 1 node in alarm. I need the symbolic information of the instance data block of FB126.
Anybody can help me?
Thanks a lot in advance.
Hsiung
SHKODRAN
Contact:
Re: [?] Regarding Profibus DP Diagnostic pakage - FB 126
Post by SHKODRAN »
See this example of S7 without using the profibus diagnostic pakage,
very easy and more fast.
You have need only a SFC51 diagnostic and SFC 20 Block move!
Have a nice day.
[dead] :/313957487/Pfa.zip
xdoit
Post by xdoit »
Thanks a lot.
SFC13 could be use to diagnostic a profibus fault, but it is not a good solution if there are mounts of salve stations.
Saimek
Post by Saimek »
Could any one upload this Pfa.zip anywhere again?
Thank you in advance.
TitusTheFoxII
Post by TitusTheFoxII »
The FB125...126 is shit...sorry
take this one
// information about the state of the DP slaves of the PROFIBUS DP master system
      CALL  "RDSYSST"
       REQ       :=TRUE
       SZL_ID    :=W#16#694             //SZL_ID for the state of the DP slaves
       INDEX     :=W#16#1               //number of the DP master system (hexadecimal)
       RET_VAL   :=MW32
       BUSY      :=M29.1
       SZL_HEADER:="DIAG_STRUCT".STAT0
       DR        :=P#DB61.DBX0.0 BYTE 258    //data record with diagnostic information
//information about the state of the IO devices of the PROFINET-IO system
      CALL  "RDSYSST"
       REQ       :=TRUE
       SZL_ID    :=W#16#694             //SZL_ID for the state of the IO devices
       INDEX     :=W#16#64              //number of the PROFINET-IO system (hexadecimal)
       RET_VAL   :=MW30
       BUSY      :=M29.0
       DR        :=P#DB60.DBX0.0 BYTE 258    //data record with diagnostic information
//DB51 - "DIAG_STRUCT"
STAT0	STRUCT
STAT1	WORD	W#16#0
STAT2	WORD	W#16#0
	END_STRUCT
//DB60
index	WORD	W#16#0
Device_status	ARRAY[0..2048]
	BOOL
//DB61
index	WORD	W#16#0
Slave_status	ARRAY[0..2048]
	BOOL
