[?]: Display real in WinCC Flexible
Usachev
Post by Usachev »
Hello. say please how can I display value (real) in WinCC Flexible. In I/O Field i'm not find real value, i'm find only decimal value.
dsekulic
Re: Display real in WinCC Flexible
Post by dsekulic »
Everything is OK. If You want to display REAL data type from plc You define tag as real. Then put Your IO filed on screen. Format type is Decimal. In format pattern You can type Your format (for example s999.999 - means signed real value from -999.999 to +999.999) or choose some predefined from drop down list.
regards
Usachev
Post by Usachev »
thank you
