Request: FB88 read R-Parameter on 840D from PLC
raimund
Post by raimund »
I need a Sinumerik 840D Standard Function Block FB88 to read R-Parameter Block from PLC.
https://support.automation.siemens.com/ ... d=23034173
Read / write a larger R parameter block from the PLC.
The function blocks FB2, FB3 (GET/PUT) allow to read/write eight parameters per job. In the example attached (FB88), up to 40 R parameters are transferred via multiple FB2/3 calls.
CALL FB 88 , DB 88 (
Read := E 7.7, // Start read job
Write := E 7.6, // Start write job
Anz := 40, //No. of R parameters
R_Nr := 5, // First R parameter
Unit := B#16#1, // ChannelNo.
Activ := A 5.7, //LED T1
State := MW 200, //StatusWord
Error := A 5.6); //Error in FB2/3
The download file comprises the required PLC blocks in source format.
Software liable for costs (spam via the AVC Automation Value Card): Image
Can everyone help me? :roll:
Greetz Raimund ;)
raimund
Re: Request: FB88 read R-Parameter on 840D from PLC
Post by raimund »
*push*
markus
Post by markus »
Hey, have u got FB88 know?
I think that maybe is the solution on my problem, if u got it, will u share?
or does anyone else have it?
