REQUEST intouch 5.1
PLC_ITA
REQUEST intouch 5.1
Post by PLC_ITA »
my customer ask to me if is possible to revamp an old application
developed with Intouch 5.1
Anyone have this old application ?
I need version 5.1 or is possible to open projet whit 7.0 ?
another question : which operating system for this old version ?
thank you for your help
Umencho
Re: REQUEST intouch 5.1
Post by Umencho »
Well, this is very old version of Intouch. If I remember, directly it isn't possible to open with 7.0 . First you must convert to version 6.0 and then to go up. And version 6.0 would be easier to find (5.1 impossible :( ).
with regards,
umencho
most
Post by most »
PLC_ITA wrote: another question : which operating system for this old version ?
the v5.6 is 16 bit
if you want try 5.6 (30 day) go to ftp://ftp.west.wonderware.com//Wonderware/INSTALLS/
most
PLC_ITA
Post by PLC_ITA »
thank you friend for your help. I have downloaded and installed V5.6 but does'nt work. A licence key (file) required.
I ha found inside the zip a .lic file but i don't know In which directory i need to put this file.
Can you help me
most
Post by most »
PLC_ITA wrote: but i don't know In which directory i need to put this file.
I test this soft in old pc with WinMe and it seems work well but in not test runtime
i use the lic for 7 and work very well
http://databridge.narod.ru/WWSUITE.LIC
http://plc.net.ru/viewtopic.php?f=14&t= ... it=intouch
i put the lic in folder Intouch.16 (intouch.lic) also (?) in folder program files/factorysuite/common/ licence
do not forget to open occult files in the SO
it only lacks to know if it opens your works in intouch 5.1 :?:
I think that yes therefore it has menu importation
regards
PLC_ITA
Post by PLC_ITA »
wow most !
Thank you, now all working fine .
Thank again.
PLC ITA
ciwa
Post by ciwa »
hi most,
could you please reupload the lic, the link is dead.
regards,
Ciwa
