need help
seach winac slot v3.2
Request: winac slot v3.2
honeyloveet
Re: Request: winac slot v3.2
Hi did you find winac slot v3.2. if you did I was looking for it too can you share it with me please it's very urgent. That you in advance.
PCS7 6.1\Additional_Products\WinAC_SLOT__V3.4+SP1
can be used on PCs with Windows XP, SP2
https://support.industry.siemens.com/cs ... t/14424111
honeyloveet
@CoMod
Thank you for your quick response. I have WinAC Slot v3.4+SP1 the problem is the firmware version in the CPU 416-2 PCI is v1.1 it is not compatible with the pc software WinAC Slot v3.4 and i cannot update the CPU 416-2 PCI firmware from v1.1 to v3.4 because I don't have 2MB Memory Card and also i dont have the memory card reader. If it is possible the compatible version of pc software is WINAC SLOT V3.1. Thank you.
