We have anew machine with plc OMRON CP1H and HMI NT11-SF121B-ECV1-CH with RS232C
But the languge of this HMI is Chinese
any one can help me to change the language to English?
Best regards
[?]: How can I change tthe language of NT11-SF121B?
asman
Homeroid_BL
Re: [?]: How can I change tthe language of NT11-SF121B?
System language is chinese, or application langage is chinese? If You press F1 and F2 during NT11S startup, do You see a System Menu in chinese or in english?
ZENDER1
you can download project from PT. Translate it by using translation support utility. And upload it back.
translation support utility and NTST-E V4.82 you can find here http://z-forever.com/w/doku.php/soft:omron:ntst. Pinouts for cable here http://z-forever.com/cables/list.php
alex0under
System language of this panel is Chinese.
Only Resource loader language is English.
More of them, I couldn't download NT11-V1 firmware to the NT11-SF121B-ECV1 (need NT11-ECV1) with NT System Installer 2.0 ("different target PT H/W").
Can anyone help me with firmware for NT11-SF121B-ECV1?
alex0under
Ok, the problem with NT11 is solved. Set DIP Switch 6 & 5 on, then power on and erase system. Install new system NT-V1 (with English). Now NT11 is English and functioning correctly.
