[?]: Problem with tags in WinCC Flexible
Volodymyr
Post by Volodymyr »
Hello!
I have CPU314C-2DP and 6 modules connected to it. One of this modules is analog output module SM332 A02h12BIT. There is also a touchpanel MP370 connected by profibus dp.
In the symbol table of the project is registered a tag AnalogOut1 PQW 336. 336 is the address of the first word of SM332.
The problem is this: if i assign a value to AnalogOut1 from organizational block, the output voltage corresponding to the module SM332 is installed, but if i assign a value to AnalogOut1 from touchpanel (in my case from slider), then immediately get an error:
PLC address error
error status ended.
There are no problems whith assigning a value to other modeles.
Maybe someone know why this happens?
