hello everyone
i have a problem to ask everyones :
1, what is different between : Rslinx lite , Rslinx Classic ,Rslinx OEM and Rslinx Pro?
2, i am using Rslinx Classic, and must i use Rslixn SDK to creat OPC Client ?
3,Can i use language DotNet to make OPC Client for OPC Sever Rslinx Classic ?
Thank you
[?]: OPC client for Rslinx
Re: [?]: OPC client for Rslinx
1 - different version of RSLinx, for OPC Server functionality you need at least Classic version
look at
2 - no, SDK is not needed, you can find many OPC Client examples with source on net
3 - yes, you can use DotNet
hope this helps
look at
http://forums.mrplc.com/index.php?showtopic=99813 - yes, you can use DotNet
hope this helps
who do have example OPC Client (write by Dotnet or Basic ) for OPC Sever Rslinx ?
Thank you
Thank you
look at
http://www.faweb.net/us/opc/sample_index.html
http://www.foxon.cz/free-opc-client-visual-basic-source-code-p-372.html?cPath=72_163
http://www.codeproject.com/KB/COM/opcdotnet.aspxRe: [?]: OPC client for Rslinx
I recommend you the ClientAce OPC .NET Toolkit from Kepware you can download from:
https://kepsfdc.kepware.com/mykepware/
registration is needed
