I need FIX32 VERSION 7 OR 6.15
If anyone have, Please Upload.
Regards
[REQUEST] FIX32 VER.7
dibolo
do you have a project from this scada?
[dead] :/292594640/fix32.rar
deeboo
If you are going to migrate from 6.15, I'd recommend going to iFix instead of Fix 7.
Getting Fix to run on newer OS proves tricky at times, You won't run into the same problems w/ iFix(and fix desktop). Plus you get the ability to pull tags out via OPC into a data collection system if you are running one.
af.naderi
Reply to DeeBoo
thanks to your solution.
but i have another problem: i haven't convertor to migrate my project from Fix32 Ver. 6.15 to IFix.
Do you have this convertor? Please help me.
Regurds
Regurds
deeboo
Assuming you have iFix already, you can grab the guide to doing migrations from http://support.gefanuc.com/support/inde ... ctp=search <- if the link doesn't work, search for "Fix Migration" on the fanuc support site.
You should not need any software outside of the full Fix and iFix installations.
http://support.gefanuc.com/support/index?page=kbchannel&id=S:KB2532&actp=search-
af.naderi
Re: [REQUEST] FIX32 VER.7
dear dibolo
i download your link and extract it. but i don't know why it doesn't extract.
winrar show this error:
"CRC failed in the encrypted file fix32\fix_99.rar (wrong password ?)"
i extract file with "dibolo" password. is it right?
dibolo
rar pass:guess_dibolo
i'm watting for the project.
af.naderi
hi
i send links in rapidshare to your email address :...
regards
regards
af.naderi
Do you have Crack for FIX32 Ver.7 ?
