i started to read InTouch® HMI and ArchestrA®Integration Guide,
where can i fine InTouchViewApp object to use ArchestrA?
i only have intouch v10,do i need to another software to use ArchestrA ?
thanks in advance
[?]: Intouch and ArchestrA
khongbaogio
Re: [?]: Intouch and ArchestrA
U need to install Intouch Application server. and it doesn't work on window XP platform, it works on window server only.
af.naderi
it 's not true. installation requirement for Aplication server 3.1 is:
1- windows xp sp3
2- sql server 2005 sp2
you must install Application server + InTouch on same computer. when you do it, and run InTouch, in menu bar you can see a new
icon named : ArchestrA IDE. click it.
create a new galaxy on ArchestrA IDE.
follow instruction on InTouch® HMI and ArchestrA®Integration Guide file.
regurds
1- windows xp sp3
regurds
DelSnos
Greetings brothers on work!!!
1. Whether there are for you documents or courses (training) on application server 3.0?
2. At registration on https://www.pacwest.wonderware.com/web/Register.aspx a site asks ID Wonderware. Whether there is for someone data for registration filling?
Thanks for the help!!!
Russian wrote:Доброе время суток, уважаемые форумчане
1. Столкнулись с проблемой по Application server 3.0. В срочном порядке приходится изучать его! Может ли кто-нибудь скинуть дополнительные манулы или еще лучше курсы!Как известно, в бесплатном исполнение докментации нет, а то что есть это тока поверхностный уровень!
2. При регистрации на https://www.pacwest.wonderware.com/web/Register.aspx необходимо знать ID продукт Wonderware! Может ли кто то владеть и поделится такой информацией??
Спасибо! Надеюсь на помощь!
af.naderi
hi DelSnos,
you don't need wonderware website,
download Wonderware video training dvd (u can find it in plc.net) and follow trainings about application server.
aslo u can read pdf files (this files made by installation Application server) and find many things.
DelSnos
Thanks!!! I have already manuals application server on an official site. The problem was in registration. Registration (https://account.wonderware.com/idm/publ ... gistration) does not work in a browser Opera!!!af.naderi wrote:hi DelSnos,
