[?]: Upload and download program from & to XBTGT1130
другие контроллеры
Antooo2010
Post by Antooo2010 »
Please i need help to upload program from HMI (XBTGT1130) and which cable i can use to connect HMI with PC
Kuzyma
Post by Kuzyma »
Hello!
You need XBTZG915 (COM-port on PC side) or XBTZG925 (USB-port on PC side). Also you could try to use Ethernet port, which is built in your panel.
But probably the main problem would be that panel doesn't contain backup copy of project and you would not be able to download project to computer.
