[?]: unitronics m-90 problem with timers.
другие контроллеры
djcatalyst
Post by djcatalyst »
im programing unitronics m-90 .
i have problem with timers .
i've set some timers in my program , but no one of them working.
when i chek the program on run , the timers didnt count the time when im activating them.
help me please . :(
most
Post by most »
it is possible that you are not to make reset in the end of a counting. if to want sends projecto for me, i try to see something
or
try the samples by unitronics.
also you make a simple project to verify the PLC if function.
djcatalyst
tnx for help .
i will upload you the project in couple of hours .. im just not near the plc right now.
djcatalyst
i uploaded the program file
check it out
http://rghost.ru/461963
thanx for help
cmos
Post by cmos »
All your timers have time base and resolution 10 sec ... so they count ... hours. Are you sure that this is what you want? :roll:
djcatalyst
no, i want to count in seconds ..
but ive try before to make in seconds .... it doesen't work also
:cry:
most
Post by most »
djcatalyst wrote:no, i want to count in seconds ..
:cry:
the timers function correctly but project is something strange.
1-start with in0
2-to the end of T0_10h start out0 and another timer T1_30h
3-to the end of 30h stop out0 and start another timer T2_8h
4-to the end of 38h start out1
5-to the end of 6,2h stop out1
6-to the end of cicle the project is blocks because T0 is on (?)
it is this that you desire, is OK, the timers working OK
if i have time i can help you, if you say which is the project that you want to make
djcatalyst
the program is not finished yet ... ive checked only the timers.
thanx for help man , i will set the timers in seconds & i will look again whats happening.
thanks alot. :wink:
