[?]: WINCC mssql 2005 install problem
rahul
Post by rahul »
dear frnd..
i am installing Wincc flex 2008 but in Mssql not install on OS Win XP Sp3.
bcoz of MSXML Problem.
it shows higher version install. :oops:
i have gone through Microsoft i remove by instller cleaner.
but problem same.So give any hint to install Mssql Proper way.
thank you..
http://support.automation.siemens.com/W ... n/36831864
FAQ wrote:Why does the installation of Microsoft SQL Server 2005 abort?
Description:
The security patch KB 954459 (SP2 for MSXML 6.0) is installed on the Windows XP SP2 operating system via Windows Update.
Then SP3 is installed on this system.
Now, if you install the Microsoft SQL Server 2005 on this system, the Setup is aborted when installing MSXML.
This file is protected by the KB installed and can no longer be removed in Windows XP SP3.
This makes it impossible to install the SQL server on this system.
