[?]: s7 200 analog signal is unstable
kambiz
Post by kambiz »
hi
i need some advice, so help me if someone can!
i use analog input AIW0 from analog module EM235. Signal on the input AIW0 is 0(4) ... 20 mA (0...32000), but that signal is unstable!
Coyote
Post by Coyote »
So, what's up. You should make the signal stable, there is no other way. You can also apply filter for analog signals (see the system block).
dsekulic
Post by dsekulic »
Maybe You have some interference in vicinity of measuring system. Do You You use screened cable?
regards
xdoit
Post by xdoit »
hi,
You should use STP (Shielded Twisted Pair) cable for that sensor and make sure only one end to be connect to earth.
rgds,
hsiung
