[?]: OP7 Upload
matthew_25
[?]: OP7 Upload
Post by matthew_25 »
Hi All,
I'm having a problem uploading an application from an OP7 terminal to protool.
I'm using an 6xv14402kh32 serial lead.
Keep getting a communications error.
Do I need a driver for this lead?
Thanks in advance,
Matthew.
cemara
Post by cemara »
turn off op7 press key: "esc" + "up", turn on op7. do not let the button go for 2 second. then let go the button. use prosave to download. good luck
