[?+]: Deleting License Key in Automation License Manager
Arthurious
Post by Arthurious »
I installed Step 7 Manager V5.4 SP5 on my PC, but when I tried installing the License from EKB., I installed the License for Step 7 Basic V5.4, now in Automation License Manager it is showing me a Trial License(14 days trial) only..It is showing me two licenses one for Step 7 V5.4 (Trial License 14 days) and another for Step 7 Basic V5.4 (Unlimited Floating License).....It shows me a License for Step 7 Basic V5.4,...when I tried to delete the License for Step 7 Basic V5.4, it is not allowing me to do so.....I dont know what mess has happened...??
What do I do now....!!
Similarly for WinCC Flexible 2008 Advanced when I installed license from EKB., my trial License shows (-1days)...I dont know what to do.....It is not showing me a Unlimited License.....
In both cases i.e. Step 7 V5.4 and WinCC Flexible 2008 Advance, it is showing trial license(even after transferring license from EKB)...Somebody please help......
Regards,
Arthurious :|
Arthurious
Hi
Please find attached herewith a screen shot of the ALM Iam using and installed softwares with license keys....I have installed Step 7 V5.4, WinCC Flex 2008 and PLC SIM V5.4 SP3....
I have already installed the long keys from EKB for Step 7 V5.4, WinCC Flex 2008 and PLC SIM V5.4 ...But my ALM shows me the unlimited key for PLC SIM V5.4 only....Other two Softwares installed (Step 7 V5.4 & WinCC Flex 2008 ) are still showing me Trial, whereas I have already installed keys for them...
Iam using ALM (Automation License Manager) of Version 4.0 SP2...
Please comment what should I do..Shall I try installing the keys from latest version of EKB...or what..?
Thanks in advance
viewtopic.php?p=878#878
http://support.automation.siemens.com/W ... n/24200966
Siemens FAQ wrote:Now in the Automation License Manager compare the file name (License Key)
of the Trial License with the file name in the "AX NF ZZ" folder.
Via the view set in the Automation License Manager you determine
the file name for the Trial License to be deleted that you then find
Mark the Trial License found in the "AX NF ZZ" directory and right-click.
Then select "Delete" in the pop-up menu that opens.
After deletion the message described above will no longer appear.
Trial keys: SIT....EKB, SIMF...EKB
If you want use Trial keys anew you need to delete trial folders *fmis and *ttis in C:\Windows and C:\Windows\System32
(example 1PQPQpexYattis, 4PUPSPPPPPfmis)
in Russian wrote:Для того, чтобы использовать триальный ключ по истечении 14-ти дней надо удалить триальный ключ SIT....EKB, SIMF...EKB из папки C:\AX NF ZZ
и триальные каталоги *fmis и *ttis в папках C:\Windows и C:\Windows\System32
(пример 1PQPQpexYattis, 4PUPSPPPPPfmis)
Файлы и каталоги имеют аттрибут скрытые системные.
После их удаления при запуске программы будет окно с предложением установить Триальный ключ
