[?]: wincc flexible 2005 and AB micrologix 1200(rs logix)
dikobraz
Post by dikobraz »
Can you help me with visualisation AB micrologix 1200 with wincc flexible 2005?
I programing AB micrologix 1200 for concrete plant and want to do visualisation with wincc flexible 2005 with reports, alarms and database consumption.
Do you have same manuals or sugestion??
Thank you!!
auto_mitch
Post by auto_mitch »
Use Kepware Server with DF1 or DF1 polling master driver to read/write tags from/to plc. Write the tags into WinCC Flexible and then you can do any visualisation you want.
dikobraz
Post by dikobraz »
auto_mitch wrote:Use Kepware Server with DF1 or DF1 polling master driver to read/write tags from/to plc. Write the tags into WinCC Flexible and then you can do any visualisation you want.
Thank you! But I need links for download this Kepware Server with DF1 or DF1 polling master, if you can help me...
auto_mitch
KEPServer EX v4.270.416
[dead] :/266188972/KWEX4270416.rar
