I need a MPI cable scheme. I shall make mpi cable for S7-300.
can anyone who have mpi diagram, hepl me ?
[Scheme]: MPI cable
Download following manual. On page 4-4 You have pin layout for MPI cable.
http://support.automation.siemens.com/W ... aller=view
https://support.automation.siemens.com/ ... _USB_e.pdf
regards
regards
ahmetnoktacom
alireza136110
Re: [Scheme]: MPI cable
thanks tiny.
but icant find this page. plz if it is posible uploade the Scheme.
If you can't open the page,
please check this page:
http://www.bestincn.com/usbmpi-v40usb-i ... _p356.html
Functions
● Support STEP7 V5.2 and higher,STEP7 Micro/Win 4.0 and higher
● Fully compatible with USB V2.0
● Power supply by USB port(100mA). with overcurrent Protection and Surge Protection
● High optoelectronic isolation voltage up to 1000VDC
● The USB port design with surge protection.
● The RS485 port design with overcurrent protection and lightning
protection:Ipp=100A(10/700us,4KV) .Accord to the standard:ITU-TK20/21,VDE0433. ±15KV ESD Protection.
● Baud rate of MPI port on PLC: 19.2Kbps,187.5Kbps,1.5Mbps. automatically adjust.
● Baud rate of PPI port on PLC: 9.6Kbps,19.2Kbps,187.5Kbps.
● Support long distance communication up to 1000m
● Working temperature -20~+75'C
● Length 3 meters.Color:black
● One pc supports one USB programming cable only
