how to write the data type as BCD, real, hexadecimal number.
and how to convert hexadecimal to BCD, hexadecimal to real.
I don't know i must use instructions
[?]: DATA TYPE
macminh
[?]: DATA TYPE
Rune
Instructions
Hi
You use the different conversion instructions, see under help menu, or in progtsmming manual, but dont get sad if you are having problems with the different data types in omron, it is not alway simple...
macminh
Re: Instructions
could you help me?Rune wrote:Hi
Rune
Hi
When you want to convert the data type, you insert a innstruction, and then in the dialog box you can "find instruction" and under the group " data convert " you will find the one you need. eks.
BCD(024) that converts your Binary data into BCD values... ans so on.
and if your are having problems conveting to/from HEX, i can recommend the calculator in windows... helps me a lot..
