Hi all,
I have a problem regarding the resolution in the WinCC Flexible 2005 SP1. I have a project using WinCC Flexible RunTime.
All of a sudden, the compiled fwx file is distorted whenever it is used in a pc other than the developing pc.
I've only tried one customer PC for this though.
I do not want to compile the project inside this customer PC, as they have a very strict policy that the developer should not be installed in the PC, even for a temporary time.
The distortion problems are:
- the pictures are smaller
- the text field, whenever I am using automatic size, is cut off on the bottom part.
I have tried compiling it using the same resolution as the customer PC, but it doesn't help. Does anyone have any solution regarding my problem?
Just some information perhaps?
Anyway, any kind of help is appreciated.
Best regards,
Wendra
[?]: Resolution Error in WinCC Flexible 2005 SP1
wendrahooreg
