Hi everybody!
I need to repair a PCS7 BATCH station and it has installed PCS7 v6.1 SP1 with simatic batch 6.1 SP2 HF2 (different from the standard Simatic Batch 6.1 SP1 integrated in PCS7 6.1 SP1). I don't know why the version is different but it doesn't work with the standard version.
The problem is that I don't have the installer of simatic batch 6.1 SP2 HF2!!! I looked into PCS7 6.1 SP2 and it has integrated the Batch version 6.1 SP3 HF9...which is different too (higher).
I neither found siemens updates...
Anyone can help me and post the installer of Simatic Batch 6.1 SP2 HF2???
And you tell me why someone could have the great idea of installing this version over PCS7 6.1 SP1.
[?]: Simatic Batch 6.1 SP2 HF2
Electroluck
Hotfix 15 für SIMATIC BATCH V6.1 + SP3
http://support.automation.siemens.com/W ... e/37592583
SB_V61_SP3_HF15_EU.zip ( 248219 KB )
https://support.automation.siemens.com/ ... F15_EU.zip
Electroluck
Thanks CoMod, I appreciate your help... but the other PCS7 Stations (ES and Batch Clients) have Batch 6.1 SP2 HF2 and I need to repair a Batch Server with this version because I discovered that the clients don`t respond to a higher batch server version (imcompatibily)
and so I would have to update all the system, which is a bigger problem.
I would need exactly SIMATIC BATCH v6.1 SP2 HF2!!!
Could anybody get this version installer and post here?
