ive looking for allen bradley plc macros in eplan p8 , but didnt found anything.
so i start to create plc card by my own ... ,
the creation of plc boxses was withot any problem , but when i create same connection point in diferent sheets , in same plc box ....
so what i see all the time that no cross reference between two points
even i write same DT , same adress , still the program see it like diferent points
i need advice how to create plc in eplan from the start
help
tnx.
[?]: PLC creation (cross reference ) in Eplan
djcatalyst
majzdor
Re: [?]: PLC creation (cross reference ) in Eplan
On schematics you must define PLC input/output as "multi-line" (on Symbol/Function data tab) and on PLC card overview page it must be "overview".
dsekulic
Did You put Cross-reference (main/aux. function) in definition of Your PLC box. If not open Utilites -> Master Data -> Symbol -> Open and in block definition insert Property text (in insert menu). Update symbol and then You have to see all cross references.
regards
dsekulic
regards
dsekulic
