[?]: TWIDO and GSM Communication
другие контроллеры
leofarhan
Post by leofarhan »
Is there anyone who have communicate TWIDO PLC with WAVECOM GSM modem.
I have tried to communicate using ASCII communication, but failed.
It seems Twido send ASCII command to GSM Modem, but GSM Modem does not respond, Is there anyway to check TWIDO is sending correct AT-Command.
Is there any tester which act as ASCII Slave, on which I can check thetransmission of TWIDO Command.
When I send AT-Command to gsm modem directly, It generate sms, I have also checked communication parameters.
Need Support,
Kuzyma
Post by Kuzyma »
Hello!
Try this solution:
[dead] :/257863905/T ... S.zip.html
or
http://narod.ru/disk/11098676000/Twido_ ... S.zip.html
I think it would be helpful for you! :)
