[?]: iFIX DEMO - SCADA and iClient nodes connection?
WH_Mike
Post by WH_Mike »
Is it possible to establish connection between iFIX SCADA node and iFIX iClient node in DEMO mode iFIX?
If it possible, please give me detailed description what settings must be made.
In russian:
Возможно ли связать в демо режиме iFIX два узла - SCADA (сервер) и iClient?
Если возможно, пожалуйста, укажите подробно какие настройки следует выполнить.
monty_burns_007
Post by monty_burns_007 »
no in demo mode, the network option is disabled so no iclient (remote view on scada servers) can be run. The client PC won't find scada server PC.
WH_Mike
Post by WH_Mike »
Yes, it is.
As soon I had soft license (even not HW key!) installed on both SCADA and iClient nodes, connection established!
:D
