[? Rus]: Intouch and russian system Galaxy
Roman
Post by Roman »
Все можно. Внимательней читай доку
Connecting Animations with InTouch Tags
You can connect the element animation and appearance with
an InTouch tagname. The InTouch tagname provides values
at runtime that control the animation and appearance of the
element.
This can be done by:
• Configuring a reference with the intouch:tagname syntax.
• Using a custom property and configuring the custom
property in the embedded ArchestrA Symbol in InTouch
to reference an InTouch tag. For more information, see
the InTouch HMI and ArchestrA Integration Guide.
• Configuring an ArchestrA attribute reference to the
managed InTouchViewApp object that contains the
InTouch tagnames as attributes. The InTouchViewApp
object uses the functionality of an InTouchProxy object.
• Configuring an ArchestrA attribute reference to an
InTouchProxy object that contains the InTouch tagnames
as items. This is a special case of configuring an
ArchestrA attribute reference.
Roman
Post by Roman »
Roman
Post by Roman »
Понял. Никак не получить. Настраивай объект до публикации. После публикации редактирование его свойств невозможно
