[?]: connection with LVD drive
привода и частотники
Igor_A
Post by Igor_A »
Somebody can help me with a problem:
There is a drive of handle of the stepper motor s.b.c. LVD 10
Has gathered as prescribed by the instruction on maintenance the communication cable of the computer with the drive,
has installed the software of configurator PC2LVD,
has hooked up a cable,
has installed port parametres as under the exposition,
but the computer does not see the drive.
Tried to use interface RS 485 through the converter, but the same effect.
Somebody can worked with these drives, prompt arrangement of soldered connections of a cable and communication parametres.
Matter becomes complicated that there is no console for programming of parametres and so link with the panel goes both on 422 and on 485 interface.
The console on rig ESA VT170W.
I hope somebody will respond, I look forward to hearing.
Igor_A
Post by Igor_A »
Thanks for attention
The reason has appeared that PC2LVD cannot work with baudrate of the drive, established parameters distinct from 19200. The special keyboard of a drive by which is setting the parameter 26 equal 6 and is initialized new connection is necessary For communication :) .
clood
Re: [?]: connection with LVD drive
Post by clood »
HI @Igor_A I KNOW ITS BEEN A LONG TIMe for this post but im in the same problem i couldnt find how to connect to this drive and i want to copy one to nother drive but i do the same wiring us the software for pc and for computer but nothing works ... can you plz show me the cable pinout or tips how to get connect to the drive .. thanks
