[?]: S7-200 + em 235 and Danfoss vlt 5000
dorofteius
Post by dorofteius »
I have a s7-200 cpu224 whith em235 module, and td200 as HMI.
I just need to read a temperature from one pt100 and RPM from the Danfoss Vlt 5000 drive.
Whith the temperature was easy, but how to do-it whith the drive? as it has options 4-20 ma, 0-10 V and 0 to 32 khz as I remember.
Whath do you recommend ?
hsbeyond
Post by hsbeyond »
it is easy, because the Danfoss Vlt 5000 can define the output sign , so you can read the RPM from the VLT 5000 through 4-20mA sign!
