These Days,i prepare to study AB PLC-5,and when i use the RSEMU5,
I have got through the problem,when i start the RSEMU5,the system remind the error"can't load the the RSEMU5X.dll form the RSlinx directory",
after that i check that the RSEMU5.dll be in the directory,
so i don't how to do, so i need help
[?+]: Something Wrong About RSEMU5
neuhauser1234
I don't know what version of emulate you're using but RSEmulate 5 5.00.08 on Windows 2000 or Windows XP requires a patch from Rockwell which replaces "We532.exe". I've seen Emu5 crash over and over from this. It's caused from v7.00 and above projects.
Here is a link to the problem and the patch:
http://rockwellautomation.custhelp.com/ ... =undefined
http://rockwellautomation.custhelp.com/ ... 52&p_olh=0
Thanks your answers
first things,thanks your reply,i have seen the answer on ROCKWARE net,
but it can't resolve the problem
i have resolved the problem
thanks your reply,
i try your method again,
and thant's right,
thank you
and thant's right,
thank you
