[?]: Problem connection between Citect and Twido port
Mesner74
Post by Mesner74 »
I can not activate the 7.0 Citect Vijeo communicate with TwidoPort 499TWD01100.
Notify the system without any problem if I connect with a Zelio.
The only way I make the comunizacione with TwidoPort is only through Visual Basic
Someone knows how to do it with Vijeo Citect? Please
Kuzyma
Post by Kuzyma »
Mesner74
What way of connection with Twido do you use? I mean do you use OPC Factory Server or direct MODNET driver?
Can you post more details about settings you use? It would be helpful if someone is going to give you some advices.
Mesner74
Post by Mesner74 »
By twido port connection using Modbus / tcpip with Modnet30
the same configuration I used with the Zelio with an ethernet port and it works without any problem.
The configuration in Modbus / Tcpip is the IP of the PLC and TCP port 502
Kuzyma
Post by Kuzyma »
Well, it seems like a problem is in the configuration of TwidoPort and Twido.
If I were you I'd check all configuration folowing instructions in Twido Suite Programming Manual (p.345)
http://www.global-download.schneider-el ... endocument
Goog luck:)
Mesner74
Post by Mesner74 »
Thanks for the link.
I did a review of the system and the twidosuite communicate without any problems via the ethernet port.
I checked with telnet open as Citect announced and I saw that Citect intent to communicate with the twidoport but no twido answered.
I found an example of communication in Modbus TCP / IP written Visual Basic 6 and by that I can communicate perfectly well with the Twido.
I do not know that other parameters are missing from 2
