[?]: How can i communicate two RS485 and a RS232 to PLC?
CX-One, CX programmer, NTST, Syswin ....
saha
Post by saha »
I want use Omron's PLC communicate to follow below :
- two RS485 ports to control temperature and inverter
- RS232 port communicate to Computer ( use Visual Basic 6.0)
Please can you help me to use which's PLC ?
Homeroid_BL
Re: [?]: How can i communicate two RS485 and a RS232 to PLC?
Post by Homeroid_BL »
For PC connected to OMRON PLC:
You need to learn/read OMRON HostLink Communication manual. For example if you send form VB (via COM1) string:
"@00RD0000..", and then rad data in VB form COM1, You will get an answer (string also) form PLC. I Tried it and it worked fine.
For E5* regulators, and inverters, You can find a proper Communication manual with DETAILED (usefull) instructions.
Homeroid_BL
Here you will fin a sample application.
OMRON C-Mode Hostlink.zip
mrmailoi
Post by mrmailoi »
Homeroid_BL wrote:Here you will fin a sample application.
hi everybody,I can not download " OMRON C-Mode Hostlink.zip",can Homeroid_BL can check link again?help me!thank you so much
