I've trying to install step7 under windows seven, even changing the settings in the ini file for the installer but nothing to do. How to manage it?
Or we'll have to wait for the hotfix?
[?]: Windows 10/8/7 and step 7 incompatible ?
Scarch
Umencho
Even the last SP5 of Step7 v5.4 doesn't supports Windows 7.
RegardsSupported operating systems:
* MS Windows XP Professional SP2 or SP3
* MS Windows Server 2003 SP2 standard edition, with or without R2 as workstation computer
* MS Windows Vista 32 Bit Ultimate and Business with or without SP1
silvia
download and install the msi tool orca https://mega.nz/#F!DsE1RDSB!Zk1D6fE-nuBGXJF74ZFGLA
edit setup.msi into hd image (no dvd) ...\CD_1\STEP7\Disk1
search ControlCondition DLG_InstallationRequirements and change Disable to Enable;
make the same in all setup.msi ; install and click in Ignore buttom now enabled.
this trick is mine and run it at your own risk
PD. IS BETTER USE:
>ENABLE BIOS VIRTUALIZATION >WINDOWS VIRTUAL PC
>WINDOWS XP MODE (NEW IN WINDOWS 7)
PD2. any know how siemens check VersionNT and LaunchCondition?
PD. IS BETTER USE:
CD_1\STEP7\Disk1\setup.msi
CD_1\STEP7\HF1\Disk1\setup.msi
CD_1\S7PCT\Disk1\setup.msi
CD_1\S7-Plcsim\Disk1\setup.msi
CD_1\Automation License Manager\Disk1\setup.msi
CD_2\S7-Graph\Disk1\setup.msi
CD_2\S7-Scl\Disk1\setup.msi
Install Vista Sp1
Install Simatic
Upgrade Windows 7 Enterprise
Flexible, PLCSIM, WinCC 7 work !
but Step7
Install Simatic
but Step7
http://www.automation-drives.ru/forum/v ... hp?t=11898Step7 wrote:Your user rights do not include the use of Step7
Russian forum wrote:Подружить WinCC 7 с Windows 7 мне почти удалось, проблема была только в момент прописывания правил брэндмауэра (работы проводились в порядке эксперимента и от нечего делать).
В принципе можно подружить Симатик и В7.
Сейчас на ооочччееенннньььь слабый комп с 512 мб и Вистой СП1 накатил W7.
Флекс и PLCSIM работают без проблем.
Надо где-то в реестре будет права для Степ7 поправить и можно работать.
http://www.microsoft.com/windows/enterp ... fault.aspx
Оговорка - то что Флекс на этой Висте пробовал помню,
а вот Степ7 на этой Висте не запускал - возможно права ещё на Висте были потеряны.
Надо начисто повторить эксперимент и устанавливать Премиум Студио целиком.
Ещё раз заострю внимание - комп слабый одноядерный 2,4 Гц и памяти всего 512 мб = устанавливал на Висту всё очень долго.
А на этом же компе с В7 Флекс работает на удивление быстро.
Впечатление от В7 после Висты, в смысле быстроты, положительные.
Особенно, когда ползунком понижаешь претензии надоедливой Самозащиты и СетевогоЭкрана.
SHKODRAN
silvia wrote:download and install the msi tool orca https://mega.nz/#F!DsE1RDSB!Zk1D6fE-nuBGXJF74ZFGLA
PD. IS BETTER USE:
I have tried this procedure, said that it works perfectly to 100% in windows 7 Ultimate 2009
If you need to see how it work,you can show here.
[dead] :/280985687/Step7.rar-
Info
- Faq & Info
Re: [?]: Windows 8 and step 7 incompatible ?
Tested Step7 v5.5 SP3 and Windows 8for Professional wrote:CD_1\STEP7\Disk1\setup.msi
waggomes
Re: [?]: Windows 8 and 7 and step 7 incompatible ?
I installed Step7 normally in Windows 8, but found a problem when I select "Insert New Object", the application crashes. It is the same with you?
genpaolo
The same happen to me.waggomes wrote:I installed Step7 normally in Windows 8, but found a problem when I select "Insert New Object", the application crashes. It is the same with you?
I try in two different computers running windows 8.1 pro.
But no way to solve this problem.
Please , help me!
waggomes
Unfortunately I didn't solve the problem.
blackducati
Step7 don't works fine at Windows 8 or 8.1 !
see here: https://support.automation.siemens.com/ ... /index.jsf
all other things make many problems...
regards
regards
Update
- Forum Community
wraith
Re: [?]: Windows 10/8/7 and step 7 incompatible ?
доброго дня ,а можно перезалить на яндекс или выложить в торенте на бабочке
