[?]: s7-200 compatible Siemens HMI
dorofteius
Post by dorofteius »
Anybody knows what other HMI then siemens , are compatible whith s7-200?
Peehel
Contact:
Post by Peehel »
You can use Proface, Delta Electronics or Weintek.
Eugene_Shats
Post by Eugene_Shats »
In case of use OPC-server (such as S7-200 PC Access for example) - anyone.
dorofteius
What do you mean by this ? :)
I know how to use s7-200 Pc Access.
Eugene_Shats
dorofteius wrote:Anybody knows what other HMI then siemens , are compatible whith s7-200?
s7-200 Pc Access - OPC-server, HMI software - OPC-client.
Choose any HMI software, which support OPC-compatible data exchange.
dorofteius
Got the idea .
I can't do that as it is a factory in witch the machine that has this cpu will operate.
And already solved whit one piece of td200, nothing fancy but good working.
Thanx for the advice :).
