[Request] Switch to Vijeo Designer "S2VD"
leofarhan
If anyone have Switch to Vijeo designer i.e S2VD Please Upload it.
leofarhan
S2VD is Switch To Vijeo Designer
S2VD is Schneider Utility which is used for internal / system integrator application.
This utility / software convert XBTL1000 file (i.e. for XBTF Series) to Vijeo Designer file (i.e. XBTGT Series Application).
The main purpose of this utility is to convert software enviorment. (i.e. XBTL1000 to vijeo Designer)
This utility is free of cost, but not available for downloading. One have to get a training in order to get this utility.
If anyone have utility, please upload it.
Links regarding S2VD are listed below
http://www.schneiderelectric.bg/forum/v ... b592603c51
http://www.schneider-electric.cz/downlo ... _ASRTP.pdf (Page No. 21)[/img]
Schtiel
leofarhan
Re: [Request] Switch to Vijeo Designer "S2VD"
Thanks Schtiel & Dustin
cesarmecatronik
hi, you can upload tje aplication again please? the links dont works
vlad2006gr
Rapidshare link is work!
carter666
Can You upload a new link? Because the link does not exist. And I have to convert an application from the XBT-F on XBT-GT. And i need the S2VD.
alimicro
Can You upload a new link? Because the link does not exist. And I have to convert an application from the XBl-1000 on XBT-GT. And i need the S2VD.
thanks
thanks
Carlos
never tested this program
gycu
Hey guys,
Thanks for the uploads.
I installed Vijeo Designer 5.0, then SP1 and XBTL-1000 4.51
I downloaded Switch_to_VJD.rar and from here I installed the "Switch from XBTL1000 2 Vijeo.exe" and after some failed attempts to convert a project, I also installed MBX Driver Suite, from the same archive.
With every attempt I make to Import a dop file in Vijeo Designer, I get the same error message "XBTL1000 has stopped before end of information extraction.
Can you help me with this? Thank you in advance!
apilife
Hi gycu,
Are you sure the DOP file is done with XBT-L1000 and not Vijeo Designer Lite ?
What model of HMI is it for ? S2VD is made for XBT-F conversion...
Could you send your DOP file ?
This S2VD is quite old and doesn't always work.
(MBX Driver Suite is not needed for conversion.)
gycu
Thanks for your reply and sorry for the late reply, I was out of town for some time.
I'm pretty sure the software is made with XBTL-1000, as it is very old and as I can open it with XBT-L1000.
The HMI is an XBTE016110, are you sure only XBTF's can be converted?
I sent you on pm the .dop
Thank you.
Cheers
Thank you.
Cheers
pazuzu
Hi everyone
Could I ask for re-upload Switch2Vijeo / Swich to Vijeo software ?
Thanks in advance
Cheers
Thanks in advance
Cheers
Garog
Reupload possible ?
ravikaneria
I Have Old software but it is not installing and asking for the exext vijeo designer V5.0.0. sp1.
if any one required the link then please ask me.
ercanbaydu
Hi
I need S2VDJ software
Could you upload a link?
Regards
Regards
