[?]: record values PLC Mitsubishi
другие контроллеры
Eusto
Post by Eusto »
How can I record values un variables without they fade when I turn off and turn on the PLC? :)
richy4620
Post by richy4620 »
With the mitsubishi only some of the data registers are retentive.
For example with the FX3u D200 to D7999 are batch backed up, the data registers that can be used for each model of plc can vary.
You need to refer to the prgramming manual for your type of PLC
