Hi to all,
Good afternoon I just want to ask if there's a relay output card for s7-300 that has normally close contact.
And also is there anyone here that has electrical wiring diagram for relay output card module of s7 because I'm confuse right now because I saw a document that has a 16 points relay output with only 20pin front connector.
I'm thinking that a relay output that has 16pts should use a 40pin front connector.
Thank you very much
[?]: Relay output issues
reymond_craig
weijah
what kind of card are you using
SM 322; DO 16 x DC 24 V/ 0,5 A; (6ES7322-1BH01-0AA0)
point 1 ist 1+ 24Vdc
point 2 to 9 are the outputs 1 to 8
point 10 is 1+ ground
point 11 is 2+ 24Vdc
point 12 to 19 are the outputs 9 to 16
point 20 is 2+ ground
http://support.automation.siemens.com/W ... 0=10805256
there you will find manuals
venix
Hello!
Here are the manuals:
For S7-300
[dead] :/235077013/s ... n-US-1.pdf
For S7-400
[dead] :/235077974/S ... _en-US.pdf
You can use some additional relays to have NC contacts or you can program the outputs for NO.
[dead] :/235080041/S44EN.pdf
Best regards!
Venix
For S7-300
For S7-400
Best regards!
Venix
