[?]: How to restart 60 seconds timer ???
Ilija28
Post by Ilija28 »
How to restart timer with Ladder logic in step7.
I need signal state "1" at every 60 seconds not always!!
sventek
RE: [?]: How to restart 60 seconds timer ???
Post by sventek »
Sorry, but what means "every 60 seconds not always"?? When do you need the signal?
greetings
sventek
komatic
Contact:
Post by komatic »
Which type timers do you use?
Ilija28
Post by Ilija28 »
sventek wrote:Sorry, but what means "every 60 seconds not always"?? When do you need the signal?
greetings
sventek
I need that signal to execute FC105 block (scale) every 60 seconds !!! It must be signal state "1" at FC105 Input to do the function ( integer to real). i need that scale every 60 sec.
Juli
Post by Juli »
You can also use clock markers in PLC
regards
komatic
Contact:
Post by komatic »
Ilija28 wrote: I need that signal to execute FC105 block (scale) every 60 seconds !!! It must be signal state "1" at FC105 Input to do the function ( integer to real). i need that scale every 60 sec.
Use something like this:
