[?]:Profibus Analyzer
kriztof
What software use with PG to troubleshoot Profibus network? Ideal solution is just a program that use my Profibus interface and build network structure and check all stations status even if bus is in a fault state.
centipede
You can use the Amprolyzer from Siemens. It´s Freeware.
http://support.automation.siemens.com/W ... 2Fmain.asp
bunglehead
Can I use it with USB-MPI adapter? Requirements list says about CPs only, is it true?centipede wrote:You can use the Amprolyzer from Siemens. It´s Freeware.
pkbiju
Thanks for the useful info, but Siemens changed the link, The link is added here
https://support.automation.siemens.com/ ... 2Fmain.asp
PKBIJU
PKBIJU
