[?]: T400 Program Download errors
g700
Post by g700 »
Process in the compiler:
Error wrote:E: Version error in code library C:\Program Files\Siemens\Step7\s7cfc\sdblocks\std\fbslib.a . Expected: 010514V612, Found: 100400V613.
E: Wrong version of GSW. Expected: 010514V612, Found: 100400V613.
E: File C:\Program Files\Siemens\Step7\s7cfc\sdblocks\std\fba121.a not found.
F: Library MAKDRA is not present.
Errors in compilation: 4 error(s) found
How to deal with?
Please advice!
THANKS!
Ksn76
Post by Ksn76 »
fba121
- Siemens library, you should ask about it author of program.
Library MAKDRA
- i think it is macro (library, that was made of standard blocks), if you have not source, you should also ask about it author of program.
- you should update all possible libraries using CFC menu Options-Block types.
And I think you need not SFC 5.2.
g700
Post by g700 »
The current situation is this:
I would like to use a v5.2 download SPW420 prepared in the T400.
But my software version is v6.0 and above.
Do you have the relevant software or procedure?
g700
Post by g700 »
I can not contact the author of the program, it should be no need to, right?
Do you have MSN? Can contact me and give me guidance to do?
THANKS!
g700
Post by g700 »
Ksn76:
I'm looking forward to your reply!
Be grateful!
